I installed a new water pump on my 1980 9.9hp Johnson, ran it and it appears to be over heating. I am not able to hold my hand on powerhead for more than 30 sec. Water is coming out of pee hole like it should. I thought it might be some crud clogging the thermostat or insides. When I dropped the lower unit the first time I cleaned and scraped a lot of crud from bottom and I thought something might have gone up inside. I opened up engine and took out thermostat and don't see anything unusual. If water is coming out of pee hole, does that mean water is circulating through the powerhead? Should I take all 3 sides off to look around? Change thermostat? Newbie learning.
