overheating ignition coil m/c 3.0
droptheline
1988 mercruiser 3.0, points style distributor, had a bad starter, got towed in, ignition coil was red hot couple hours later, little oil bubling out of it, talked to someone here and he said hopefully my selinoid was engaged, got a new one, same deal way too hot, everything seems wired right, boat starts and runs ok, so was wondering if anyone had any ideas?? Thanks
Re: overheating ignition coil m/c 3.0
Ayuh,...
What's the Voltage on the (+) side,..??
droptheline
im not geating a positive reading with the key on (not running). got like 1.7 ohms between the two terminals. Should there be a 12 volt constant?
droptheline
ok bad batteries in the multi meter, so i got 12v @ the + even when the key is off, im guessing its not suppose to be doing that, if the coil sits on without running will it get very hot? if so this is my problem, should i wire it to the acc. on my key switch? i dont use it for anything else, thanks for the help
Ayuh,....
You Guessed it,... That's Not Right...
I'm surprized the battery isn't Dead all the time....
The Acc. post on the keyswitch isn't the answer Either,....
Finding the Problem,+ Fixing it Is the thing to do.....
Otherwise,... It'll just lead to Other Issues later.....
jack gardner
im sure 9 volts is required at points on 12 volt system .also if key is on and points are closed coil will get hot coil buildsvolts when points closed fires as points openrebuilds as points closed closed points with ign on ovreheats coil
