greatestfisherman
- Joined
- Dec 2, 2009
- 76
Hi All,
I just had my carbs cleans and was in the mist of readjusting my idle screw... my motor is a 1992 Yamaha pro v p200tlrq... I took it out this morning and was running fine for a few minutes then the overheating alarm went off.... the water pressure is fine (new impeller)... the thermo was replaced last year with new gasket... it ran fine all year last year... im assuming the issue is carb related since it just started after the carbs were redone.... can an over loosen idle screw cause too of a rich mixture thus overheating the motor? service manual stat 1 1/8 - 1 5/8 turns.... i had it set to 2 for the top carb and 1 1/2 for mid and 1 for bot... with this settings it seemed to idle fine and I don't think its too fuel efficient... after the alarm went off, I let it cooled and readjusted the screw to 1 1/8 for both top and mid and 1 for bot... ran it for more than a few minutes and alarm did not go off... can someone verify my assumption or enlighten me.
thanks in advance...
