bobsquatch
- Joined
- May 20, 2013
- 154
My 1973 Johnson 115ESL73 115HP has just started overheating under load. This just started 2 days ago after a day of fun tubing/cruising with the kids. All good all day long. The last 30 min of the day I was making a sustained high speed run near maximum rpm for a little thrill as we ended the day. As we made our final turn toward home dock my temp alarm went off and I shut down to idle then off within 15 seconds. I checked the intake for blockage and pulled the cover and confirmed the motor was hot. No blockage on intake but steam+alarm on restart so I called for a tow. Yesterday I ran on muffs with a temp gun and all is well so I decarbed the engine with seafoam per instructions on this site and launched again. All good at idle but under any load it gets hot fast and alarm goes off. I let it sit for 10 min then restart with alarm screaming but I see enough water spitting out the relief ports to let it idle the 30 seconds it takes to cool off and silence the alarm. I idled around long enough to burn my 1 gallon of fuel with the seafoam in it and took her home. I just replaced the intake screen, water pump impeller, shift shaft oring seal and lower unit oil. I went on a 30 mile open ocean sea trial to confirm repairs with no issues. I am thinking thermostat blockage as the thermostat appears to be working but not flowing enough water for heavy loads. Any thoughts?
