spinalcracker
- Joined
- Jun 22, 2011
- 31
I have a 1968 Mercruiser 120 with a pre alpha outdrive. I replaced all the bellows, shift cable and outdrive this summer. I have a temp guage that is yellow then green then red. When I start the engine muffs/lake the temp will raise up to the line between the green and red. If I run the engine at 3500rpm for a minute or 2 the guage will be in the red, then I go back to idle and it will return to line between green and red in a min or 2 of idle. I have a new inpeller when I redid the outdrive and just replaced the thermostat thinking that was the problem. What else do I need to check/change or does this motor run this hot all the time?? Water is coming out of the prop when the engine is running so I think water is circulating through the motor.
