Overheating Problem
NASCARMAN
I have a OMC Cobra/Chevy 3.0 4cyl that overheats at speeds above 25 mph for more then 5 minutes. The engine stays cool below the 25mph mark no matter how long you run it for. I have changed the t-stat and even the impeller. I have even taken off the drivebelt and hand turned the water pump (which seems to be fine and no leaks showing). I have check the inlet screens for blockage (they also looked fine). Is there another screen inside the lower housing that I need to check and/or is there something else I'm missing? I will say she runs great and has in the past.<br />Thanks Peoples :confused:
Bluefish
Re: Overheating Problem
Ck the riser on the exhaust manfold for blockage.<br />Good luck
clanton
After you do as Bluefish said and check waterpump on outdrive, remove the theromstat housing and look for app 1/2 inch hole that allows water in block, I have seen this hole completely close from rust. When this hole is restricted water will not flow thru block.
NASCARMAN
I'm on it guys. I'll let you all know what the outcome is.<br />Thanks, Steve :)
