I got some good advice last time, tried it all and still having the overheating problem.<br /><br />Scenario: Volvo TAMD41A diesel engine, <1000hrs on it and it starting overheating. Found some pieces to an impeller that disintegrated in the oil cooler and thought we solved the problem, but that wasn't it. It idles fine all day, but when brought up to anything close to 3000 RPM, the temp goes up to 200 and we shut it down. (The exact engine sitting beside it doesn't hardly even get to 160).<br /><br />Things we've tried:<br />Removed and cleaned oil cooler<br />Removed and cleaned closed water heat exchanger<br />Removed and cleaned aftercooler<br />Removed and inspected the water pump<br />In the process of the above we ran a "snake" through every hose to make sure that it was clean<br />Got underneath the boat to check the thru-hull, it was clean<br />Strainer was clean<br />Replaced the thermostats (wrong ones maybe?)<br />Tried two different gauges<br />Opened the valve to the thru-hull all the way (bad valve?)<br /><br />I know on gas engines a busted head gasket can make it overheat, what about a diesel? Any other ideas would be greatly appreciated.<br /><br />
