Overheating/VRO ??
Bennett
1990 60hp Johnson VRO<br />I will be replacing my water pump and T-stat in this motor. What about the other Overheating mods, sensor wire tattle tale routing ect. Where can I find the info on the mods ? After I complete the work, can I test the motor on the water muffs ? How long can I run the motor on the muffs. Thanks
seahorse5
Re: Overheating/VRO ??
Some instructions come with the factory water pump kit. Others are in service bulletins that your dealer should have.
Bennett
Claton I tried to contact you by E-mail (Failed) is that your correct address ?
clanton
Thats it, try again, I will send you some info. You spelled the name wrong in your post, check spelling in email.
