overheating
shaenjay09
hey guys, got a question
i have a 1988 3.0 mercruiser alpha one i/o. the problem is that it only over heats in gear at a idle. neutral or any kind of throttle its good. i replaced the whole water pump, the water pick up hoses, temp sender, t-stat. and it still does it . any idea whats going on.
thanks
shaenjay09
Re: overheating
also it was fine for 3 weeks after i did the water pump. and i tokk the boat out and ran it at wot for the first time and thats when it started.
dubs283
Re: overheating
what is the idle speed??
did you check the water passages in the drive, transom assy hose, coolers (if equipped) for blockages/kinks/impeller pieces??
shaenjay09
Re: overheating
yah i just did the bellows and double checked everything while i had it apart. new water hoses. pulled manifold end caps and replaced the water shutter. im stumped. it idles in gear at 700
