Re: Overheating!!!!
Hi, I just purchased a Baja 272 with a Mercruiser 454. The boat has 213 hours on the engine. I just changed the oil/filter and the fuel filter. Took the boat out and it started to run hot, so went right back to the trailer. I then changed the impeller and Thermostat. The impeller was dry rot and all cracked up. Inspected the hoses and did not see any missing fins so put it back together. Took the boat out again, ran strong for 10 min then shutdown due to overheating. Is there an impeller in the lower unit that needs to be changed? Or is there something else I should look for?
Ayuh,.... I'm gonna Guess ya got a Bravo drive,..?? If so, no impeller in the drive,...
When ya had the motor driven raw water pump apart, were there fins missin' or not, ya said ya looked,..??
Did ya back-flush out through the drive,..??
As noted, 200 hours don't mean squat, what's yer serial numbers, what vintage,..??
Ya gonna test to see whether water is gettin' In, 'n if so, can it get Out,...
If the impeller pump is Pumpin' In,..?? Are the riser passages clear, so's the water can get Out,..??
Doesn't yer boat have a heat gauge,..?? Why'd ya Run it, til auto-shutdown,..??
