fishez4aliving
- Joined
- Dec 22, 2003
- 12
I got a used 2000 Ficht 150 and rigged it on my boat. I was told to put a 14 1/2x 19 prop on it. I rigged an aluminum prop on it, but i can only get 4300 RPM's. The engine runs great, idles great, starts immediately. But I know that I should get 5250 at WOT. It's on a 1976 SeaCraft 20 Master Angler, with the big center console, and t top. This engine sounds too smooth to be running on only 5 cylinders. I'm getting the service manual within a few days, but thought maybe i could get some feedback from someone. Could I have a fuel problem? I dont have any surging.....smooth running engine from idle, which is 700 RPM to what i get at WOT 4300 RPM. Also I got the systems check tach as well as a systems check controls....at start up each light goes on and off across the guage, but there is no buzzer. Is that something i need to buy seperately? I didnt see anything on the wiring harness to tie in a buzzer. Just the big plug for the tach...and the ring terminalleads for tach and power tilt and trim. I have an water pressure guage i want to install, do i just t it off from the pisser? Thanks so much for any replies.
