Just installed my tinytach(works great).Its on my 14'Lowe1448 alum boat with a 87'20hp Johnson.My manual says the operating range is 4500-5500.My current prop is a michigan match 10/13 alum.After doing some test runs I was able to achieve 5070RPM with just me(218lb)and I've also added about about 120lbs to the boat in the way of a floor/casting deck/battery/etc..The maximum load capacity on the boat says 550lbs.So i would say I had a medium load when testing my WOT RPM.So,is this RPM O.K. or do you think i'm overpropped?I want to get a stainless steel prop and dont know if i should order the same pitch.Any suggestions?
