Xesvuli420
- Joined
- Sep 20, 2009
- 144
Bought a 17' Dixie. the trailer is obviously for a much longer boat.
When the boat is far enough forward to rest on the rubber "V" of the wench, there is so much tongue weight, a very large man couldn't budge it. This is killing my gas mileage, and also causing horrible wear and tear on my truck.
If you look at PICTURE 1 You can see that the boat is too far forward of the axle causing a bad weight distribution. Bringing the boat back some (hopefully about a foot) should get it closer to correct.
If you look at PICTURE 2 you can see my existing wench. I have labeled "A", and "B" to help explain what I'm about to do.
If you look at PICTURE 3 You can see I have a little more than a foot to come back and still be on the existing standards. Not saying it will take that much, but, you can tell the trailer wasn't made for this boat.
***I actually had to remove a roller at the back to allow the stern to come full DOWN.
HERE is our plan
We are going to lift it with either 2 2" 20,000lbs straps or 4" 40,000lbs straps and a Front-End Loader. Reposition the boat on the trailer, and then pick up on the tongue. HOPEFULLY we will get it close to "balanced" before we run out of sliding room from the wench. IF we do, then we will have our positioning, and only have to worry about moving the wench back, and standard height.
As far as the wench, if you look at PICTURE 3 we will be completely removing "A", and sliding "B" as far as needed. Then we will have to fabricate and weld a new support arm for that rubber "V" stop.
HERE is where I need you experts
First off do any of you see any issues so far (besides buying a new trailer)?
Secondly here is my concern. If we move the boat back on the trailer, will I have to do anything with the height of the Hull Support Standards? I'm not sure if I will have to back the trailer in water MORE or LESS. I'm thinking that since the boat is further back, then it will start floating sooner, and require less trailer in the water then now.
Anything else I need to keep in mind, or anything I've over looked? I like to have as much anticipation as possible before I do something like this, so your opinions are appreciated.
Thanks
HERE is our plan
Thanks
