No more boats
- Joined
- May 4, 2023
- 59
2001 OX 66
2 stroke
250 HP
Last week changed WS filter & engine primary filter
During week started daily letting it idle 5 minute each day,- water pumping thru strong.
other day while Idling heard that starving for fuel sound , Engine DIED ?? HUH - why ?
Removed WS filter checking gaskets along with primary , seemed OK , added fresh fuel both
Opened gas gap too allow ventalation , ( just too make sure )
1/4 tank fuel
fuel in WS clear bottom
fuel in primary clear canister
Pumping ball I hear fuel , but dont know how much is pumping
Turning key ( one turn ) I feel fuel pumps within VST working
Hit shradder valve , dry
opened VST drain dry
3 low pressure pumps ,
How does this process work , low pressure pumps into VST tank ,
what would cause low pressure pumps too fail ?? fuse ?? on this model OX66 there is no fuse panel , only on inline in fuse box with some sort of breaker that has 3 connectors with 4 leads out of each connector
High pressure pumps from Vst tank into rail .
If there was a weak low pressure , all 3 ? whats the process too prime it , maybe I got too much air into lines changing filters ?? , VST should not be dry ( generally how much fuel is stored in VST tank ) ?
If it was electrical I would not feel pumps working but for what ever reasoning no fuel coming into VST too start engine
HELP and thanks
2 stroke
250 HP
1/4 tank fuel
HELP and thanks
