Oxidation Removal how to.
Status
Not open for further replies.
JasonBo
A while ago I ran across a Oxidation Removal Post on a Bass boat site I went to. This information is very helpful and I thought would be good to have here. Plus this will save you alot of money form doing it the wrong way the first time as I did.
Most boats can be brought back to look new by doing the wet sanding/compounding/glazing/waxing at home for the costs of the products and a high speed sander if you do not own one.......a lot of labor involved, but can save you big $$$$ over a re-clearcoat.
All the peripheral hardware should be removed from the boat, cleats, handrails, lights, windshields, decals, anything that can be unbolted from the top cap and consoles, etc will make the job easier....less obstructions when using the buffer.
You will need a high speed buffer, not an orbital buffer, the high speed produces the heat that makes the compound cut thru the faded clearcoat, you can use a cheap buffer, no need for an expensive model.
Harbor Freight has an inexpensive 3,000 rpm model.
http://www.harborfreight.com/7-inch-variable-speed-polisher-sander-92623.html
8 inch 3M waffle polishing pads.....the white one for compounding/cutting and the black pad for glazing/polishing.
Wet Sandpaper in 1200/1500/and 2000 grit. The grit can be matched to the severity of the oxidation...if it is real bad you may have to start with 800 grit and work up to 1200 grit.
3M Perfect It Rubbing Compound
3M Marine Finesse-It Ii Finishing Glaze
Any hard Carnauba Marine Wax
1st step is to remove all the hardware you can.
Wash the boat, remove any tar, bugs , etc stuck on the glass.
(try a Test spot with Buffer to see maybe if sanding is not needed if oxidation is not that bad.)
Sanding is always done by hand
Wet sanding allows the sandpaper to be cleared of gunk and not clog and also allows the contaminants to flush out of the sanded open pores on the gel.
2nd step is to wet sand by hand with plenty of water, put a few drops of dishwashing liquid in the sanding water to make the paper slide easier, dunk the paper often to clean the sanded material off the paper.
Start with the 1200 grit, sand the whole area to be redone, rinse off with the hose, repeat with the 1500 grit, and rinse, then again with the 2000 grit....this is very labor intensive , may take you a few days to get thru , don't sand too hard in one spot, keep feeling the sanded area.
Really heavy rough oxidation If it is rough, try a test spot and see if it works. Start with 800 grit and then 1000. Wet the paper. keep feeling the sanded spot to see if the flakes are actually thru, or if it is starting to smooth out. If it starts to smooth out with no flakes, then sand it smooth, compound the test spot and see how it looks compared to the original finish you started with. If the rough feeling is gone and no flakes are showing thru then you know you can do the rest of the boat.
if you feel any of the metalflake ( rough , grainy ) ((Make sure it is not rough oxidation you are feeling, if the oxidation is bad enough sometimes it can feel like flakes.)) stop sanding on that area or you will sand too deep and expose the flakes.
If you can feel the rough oxidation sand until it is smooth, you should be able to see the contamination coming off in the water, turning it murky. If oxidation is light, sand until the water is not real dirty.
When the sanding is done , wash the boat again to get the glass clean of particles, it will look dull but not faded.
3rd step is using the high speed buffer with the white 3M pad and the rubbing compound, do small areas and move the buffer slowly, not keeping it in one spot or it might burn the gel.
When done compounding wash off the compound and dry the boat.
4th step is using the black 3M pad on the high speed buffer and the 3M final glaze to put on a high gloss glaze coat.
Make sure you cover the carpeting in the boat with a tarp or plastic to keep all the material off the rugs.
By this time if their was not any actual gelcoat damage the clearcoat should look almost new again.
The final step is putting on a good coat of high carnauba paste wax....then keep the boat clean by wiping it down as soon as it comes out of the water with one of the spray wipes like Bass Boat Saver..
Pro-Tec makes an excellent polymer sealer for the gelcoat, bonds to the glass and seals the pores to help prevent oxidation.
http://www.protecproducts.com/products.html
Note
Don't waste your money on NewGlass , Poliglow or any of the other " quick fixes " for restoring gelcoat.
It is an acrylic base, in the same family as Pledge Future Floor wax.
It will only make your gelcoat shine if it is in very good condition already.
If there is any slight oxidation/dull spots, it will still have to be wet sanded or compounded off before using the product. Otherwise you'll still have the same dull looking gelcoat, just with a coat of hard wax on it.
All tend to fade/peel after a year or so of normal use in the sun.
Ack
Basscat7
bbcboards
Yacht Dr.
Re: Oxidation Removal how to.
Good post ... really ...
But..
Your talking about Gel Clear over Gel metal flake...
Bass boat metal flake That is damaged to the point of Breaking the point of the clear is a Totally differnent thing.
There is no Real quick fix to buffing out a Gel-metalflake bass boat other then buffing out the gel clear..
As soon as you break that clear open then your done for.
As long as you have enough material to Sand and buff..your ok..but burn through that..then you should reconsider your options..
Never IMO put wax on gel !! Carnuba or otherwise...
Peace..
YD.
Yacht Dr.
But..
Peace..
YD.
"Im Curious to why? "
Wax is not thin enough to fill the pores in gel...trapping 02 in your gel.
Wax is a carniverous coating...once you put it on there..your gonna have to feed it more and more..untill it simply breaks down and you have a crap load of stuff on there where you wont have the muscle to take it off without a Pro...
Anything on gel is IMHO Worthless ( aside from a sealer..which the jury is still out on that :) ).
YD.
MainShip36
I have done some researhing on this myself and I found what worked great.
Go to http://shurhold.com/ website and get their orbital polisher with their buff magic and pro polish.
The buff magic will bring back your fiberglass with a great shine and then put the pro polish over the top to protect.
There are also some great youtube videos on this.
I have been using this for the past two weekends and I am very impressed on how easy it is to do.
Yacht Dr.
This will not work for the long run..
If you even consider this..just look at what has been posted here on Iboats... the right way.. or the quick and the dea.. I mean ez way..
Please trust me on this one...or dont .. its your money m8 :)
YD.
MainShip36
YD.
Could you post some link from this site as to what makes this a bad idea?
Yacht Dr.
I cannot recall any post that deems this a bad idea....
Thought here..I dont search the forums for advise though....so...Its still a bad Idea to have some kind of micure all agent to shine up your gel...
just me though...
YD. good luck m8s..
oops!
the cur all agent for gellcoat is a fantasy.
snake oil will make it will look good for a while.....then you are back with the same decisions re surface the gell....rubbing compound or more snake oil.
i must admit....i havent done bassboats with flake under clear.(besides a polish)..there is not many here....and i wont touch them due to the problems that can arise.
but what i have done.....i have used farecla for clear, with good results lasting two seasons now.
Status
