1988 5.7 Cobra sterndrive.<br /><br />I took my P/S Oil cooler out today to pressure test. When pressurizing the water passage, it is leaking at each of the "end caps" (between the water passage and the outside air). I believe it holds pressure (20 psi) in the oil passage (results in the morning). If I can remove and reinstall the endcaps with some sort of sealant and then maybe some hose clamps for good measure, will I be ok. It seems to me as long as oil can not leak into the water and vise versa (this is determined by pressurizing the oil passage via the oil inlet, and plugging the oil exit) it should work effectively. I suppose I may get a drip or two of water into the bilge every once and awhile, but this may be acceptable considering a new oil cooler is around $300. If I glue the "end caps" back on with expoxy it may seal back up...<br /><br />Does this make sense, or do I need to get a new cooler? If so are there any aftermarket ones that may be less expensive?
