DaveG55
- Joined
- Jun 17, 2012
- 144
'94 Monterey 206SCR
5.0L / Alpha I, Gen II , Engine SN OF157289, Drive SN OF317617
Time to change the alternator belt so I'm going to replace the P.S. belt at the same time since it has to come off anyway. Today I took the numbers for both belts directly off the belts. The numbers are; Alt #57-816295 DF, P.S. #57-46120 DF. I can find the alt belt, no problem but I've been unable to find a belt that matches the ps belt #. I have the manual for the engine as well as a complete parts list and they indicate that there are 2 types of mountaing brackets, stamped and cast. I'm 95% positive I've got the cast mount but, since I did not know to speciffically check that, I'm not 100% on that. In any case neither belt number listed matches what I have off the belt in the boat. The number listed for the cast mount is 57-37619Q, a 52" belt. If I have the stamped mount then 2 belts are listed, 57-81295Q (52'5") and 57-37619Q depending on pully diameter - something else I did not know to check...
Anyway, I can find the alt belt but I'm unsure why I cannot locate the belt to match the number of the belt that is currently on it. Can anyone shed some light on this for me?
Also, is there any automotive equivilent for these belts? At $30 - $50/ belt (depending on the on-line shop) I'm wondering what is so special about these v-belts and would a Gates belt work just as well? If so, does anyone have Gates, or some other brands, numbers for the 2 belts?
