P200 o2 sensor
khenry
Hi,
Can someone please tell me if a 1997 Yamaha P200TLRW 2.6L has a oxygen sensor? and where it would be found? Thank you for your help.
Don S
Re: P200 o2 sensor
It does not, the P200 is a carbed engine, the O2 sensor if for EFI. Sounds like you may have a problem with your engine and searching and reading in all the wrong places.
Why don't you just post what the problem with your engine is.
khenry
Re: P200 o2 sensor
Thank you Don. I have posted the problems with this motor, and I have received the most unbelievable help thats worth a million bucks! Thank you again. But I am still having problems at WOT, if I let up on gas, it bogs, turn key off then on, it takes off like a bat out of hell, and runs better if motor full tilt down. Another member suggested that it may be a sensor going to safe mode, and turning key off then on, resets it. Oil tank sensors check good, tanks cleaned out, and new oil pump and lines. Describing the problem is difficult, can take video if that would be better?
Thanks again for all your help and time.
