Re: paging dhadley!!!!
unfortunately no they both rotate the same way - oh well....<br /><br />the sounder that was using that ducer died and i have another unit installed which is "shoot thru" - just haven't gotten around to removing the old one yet. any suggestions how i should remove the wedge ahead of the ducer? appears to be glued on, but thats trying to look through 15 years of bottom paint!<br /><br />since you mention a 12" clearance to anything, then could/would the port side tab be close enough to upset the flow? (since this is the one used the most)by the way, the motors are "all the way down" on the bracket, so the drives are buried in the water as far as possible. motors were one set of holes "up" when i bought it and i dropped it down to its current position which prevented the prop aereation experienced before.
