FuddleyPJones
- Joined
- Apr 10, 2010
- 15
I'm in the throws of tearing down a 17' fiberglass boat that has been sitting uncovered in the New Mexico sun for several years and I have some questions.
1) There is an oxidized layer on the surface of the whole boat that comes off with a lot of elbow grease and rubbing compound. The result is a shinier surface. Is this paint or is it a gel coat that I am looking at? The surface has checking on it and the rubbing compound gets into these small cracks and greatly magnifies the apperance of these tiny cracks.
1a) Does the checking mean that I need a new gel/paint coat?
1b) Can one paint over the small checking or does it have to be completely sanded past the checking?
1c) What kind of paint would one use to paint a boat?
Part of the boat has a stripe all the way around it with silver glitter in it. The glitter is embeded in the coating. Again - is this paint or gel coat? Can it also be painted over?
This is a low budget project and I ain't plannin' on entering it in the fair so is it possible to paint my own boat? What kind of paint? What kind of surface prep is needed?
I was back at the stern in the bilge area and notice that there are several areas that the wood surrounding the gas tank is rotten towards the bottom - but nothing that is structural. I also noticed that the small wood beam running from stearn to bow has fiberglass peeling away )just the last foot by the transome) and the wood is wet but not rotten. Can I reseal this wood? should I use only fiberglass or can I use a tar or rubber sealant to cover and seal this wood as well as the area of the bilge?
