Re: Paint FG advice?
you sure don't have to spray interlux poly.. that's the beauty of it. use the roll & brush tipping method .. mix the paint with their 333 thinner , it's special cause it's slow to evaporate, mix it with the paint till you knock the heavy paint thickness out of it.don't be scared , it's not rocket science ,just not too watery .. you'll know when .... pour the mix in roller pan,, roll it on with a thin foam roller . do a section at a time, than tip ( go over ) with a good FLEXABLE natural brush dipped in a little 333 thinner as you go ..THAT'S THE TRICK .. just use the brush tip to knock flat the air bubbles. if the paint starts to pull stop : wet brush with more 333 . then roll cover another section an repeat. the beauty is you don't have to ( don't bother ) in trying to get it lookin' perfect,,,( cause it ain't gonna happen ) blending one done section with another .cause if you mess 'round to much you'll have a one '' PULLED PAINT MESS '' the secret is in the 333 thinner & the oil base paint .. takes along time to dry an gives it time blend together into a beautiful job.. IT takes 2 coats & takes the rite day also,, perfect spring weather an not windy.. comes out lookin' GRRREAT !! you can do it !! i did ...
