paint for inside
thejeepster02
I would like to hear some suggestions on what type of paint to use inside the boat.<br />This wouldn’t be any where that people would walk. I’m talking like inside storage compartments and under benches. It most likely will get wet at some time but only if it rains while fishing.. Other than that it’s on the trailer covered.
thehermit
Re: paint for inside
jeepstah,<br />After a recent post here and some help I just got through using Interlux pre-kote with Brighsides on top (4coats all together) very happy with results. hermit<br />PS calling 18rabbit...he can help
petrolhead
For the "hidden" parts I'm a fan of garage floor paint, the one I use is a polyurethane alkyd resin, it's durable and resists oil and fuel spillage as well as water, just what you need in a boat. <br />The single pack "bilge paints" sold by most manufacturers appear to be pretty much the same formula, but at twice the price becaue the word "boat" is on the label!<br />It's a satin finish, usually only available in mid-grey or tile red, and a non-slip version is available too.
thejeepster02
thanks.<br />I was hopeing for white, how about a good house paint?
Boomyal
Originally posted by the Jeepster:<br /> thanks.<br />I was hopeing for white, how about a good house paint?
ok, if you want to be scraping and repainting real soon. Get a good paint and primer that is made for the environment that it will exist in.
18rabbit
Here’s my take on it:<br /><br />It depends on what the finished surface will be exposed to. All topside marine paints repel water (splashing or rain). 2-part polyurethane is the most durable. 1-part polyurethane (Brightside) is marginally less durable, but easier to apply. Even polymer paints (less durable then any polyurethane) are a good choice and will hold up to foot traffic and most abuse. And lastly, enamels, cheapest, but use only if the finish area will not be exposed to stuff banging around on it. Enamels basically give you a finish color that’s ok with temporary exposure to water, but don’t protect as well against chemicals. Marine enamels tend to be a little beefier with additives for chemicals and/or uv.<br /><br />If you use any enamel, keep in mind you may have an issue if you need to repaint in the future. The solvents in some polyurethane paints are not compatible with enamel so you may need to re-paint those areas with enamel again or apply a barrier coat before applying a polyurethane paint. You would do a test on an enameled area to see.<br /><br />Bilge coats are not recommended for topside use. I think (don’t know) it may have to do with exposure to uv. If the area will be exposed to the sun you may want to consider paint with uv inhibitors.<br /><br />If you want an Interlux product, take a look at the Brightside (polyurethane) the hermit mentioned, and Toplac (silicone copolymer). Interlux knows marine paints. Primarily made in England. The parent company also owns Awl Grip (2-part polyurethane).
thejeepster02
I think I will go with the Brightside. can you use any brand thinner or should I buy there 333 they recomend?
thehermit
hey rabbit....now a subscriber to powerboat reports! look forward to getting it.<br />jeepstah...333 is brushing liquid...216 is thinner
Boomyal
Originally posted by the Jeepster:<br /> I think I will go with the Brightside. can you use any brand thinner or should I buy there 333 they recomend?
If you have any automotive paint reducer, you can use that. I'm going to spray my Interlux, so I have to thin it. I don't think you need to if you are going to brush it. They say that a brush job with the Interlux looks like you rolled it. Very smooth.
JasonJ
I used regular polyurethane paint, $22 a gallon at the hardware store, any color you want (its base stock is white or gray, they can mix it any color from white), for the entire inside of my boat. It has held up perfectly so far, is very durable and shiney, and for what you need it for it is more than addequate for the task. No need to be all spiffy for storage compartments. If it is good enough to drive a car on, it is good enough for the compartments of a boat. Good luck...
