Paint Q
Tafflad
Had some small scratches to deal with on my Alpha II skeg.
Final job getting ready for new season ...
Treated properly ... sanded down, washed with solvent, 2 coats Mercury primer, followed by 3 coats of Mercury Phantom Black paint.
Looks OK ...
The Q is .... if this were a car, the next step would be to flat it off with 600 grit, then apply 2 coats of clear coat lacquer.
Is this recommended for drives, or should I just leave it at the Black paint finish.
The only clear coat I have is standard automotive.
Fun Times
Re: Paint Q
Honestly there's no real need to apply any clear coat unless maybe you're entering your boat into a boat show of some kind.:)
Clear coat seems to have a tendency to peel easily and water pressure at speed would probably speed up the process.
The quality of Mercury's Phantom black paint is really good.
Tafflad
Re: Paint Q
Thx ... I had assumed clear coat may not do well, thanks for confirmation.
Re: Paint Q
its an out drive that you will probably scuff the paint again.
gm280
Re: Paint Q
If you are using rattle cans for the paint, then I agree with the above answers. And I don't think anybody is using lacquers anymore for car or boat painting. However, if you are using a paint spray gun, then I think the addition of clear coat(s) do make a difference. Clear coat top coats use catalyzed mixes that are harder then rattle can paints and do offer much better wear and scratch resistance. But they have to be applied via a paint gun...
Tafflad
Re: Paint Q
This is rattle cans ... and I have rattle cans of clear coat, automobile ones.
