Not knowing your project.
Do you need a primer?
Two part epoxy primer and then cheap paint?
Most paints don't need a primer when bonding to gel coat, a sanding primer does help to hide all of the minor defects in the surface though.
There are lots of choices on a low cost easy to apply paint for a 12' FG boat that don't involve a pricy primer.
NEW NAUTICAL COATINGS, INC. 14805 49th Street North ? Clearwater, FL 33762 ? 800.528.0997 ? 727.523.8053 ? FAX 727.523.7325
They have an 800 number. Call them and ask them about using Rustoleum Premium Industrial Oil based paint.
Sold @ Lowes. Less than $30 for a Gallon. Lot's of guys on here use it on their boats. If they say YES then I'd go for it.
I'm not neccassarily looking for a cheap top coat i just wanna know if i can use something they sale at lowes or home depot
Sea Hawk "tuff stuff" two part epoxy primer.
Tuff stuff is sold mainly for a bottom "barrier" system..
That stuff goes on like melted marshmellows..so warning to ya. ( thin it ).
Im a certified applicator for Sea Hawk.
Im sure your going to end up sanding it before the topcoat.
GL.
YD.
I have no idea... Never used rustoleum before..
Bond-o would be more able to help.
I can tell you this though..you will not be able to topcoat without sanding first.
YD.
Donno,... Never seen this primer stuff you guys are talkin' 'bout....
Read the specs on the links Woodonglass posted...
Rustoleum will stick to about Any hard dry surface,...
Donno about epoxy as it's kickin' off....
Ok well thank you guys anyways... I'll post pics and let you know how it goes!
YD.
PS. Dont mind me..Ive been down with the flu for a week now..kinda edgy.
So you plan on going with the rusto ? or did you choose something else ?
Kinda frustrating when peeps ask for help ..then in the end the response is " thanks anyways..ill post pics when im done " kinda thing.
YD.
