Paint the inside of hull on 1964 Starcraft...help?
jdwilliams1
OK, the motor is getting close to running perfect and the seats will be back from upholstery this week and now I have to finish up the hull.
My question is I need to refinish the inside with paint and I need to know what process you experts would take to do this the right way....
Products, paint, sanding necessary etc.
Thanks in advance.
Woodonglass
Re: Paint the inside of hull on 1964 Starcraft...help?
Check out page#10 in my "My Flamingo" thread listed below. It has all the info you need for painting your deck with Rustoleum. Your boat looks a lot like mine. You could also Gelcoat you deck. friscoboater has a video on that. I chose to use the Rusoleum and a little bit of sand for texture. I like it a lot. But my boat is used mostly for cruising. Not to much KID activity in her.
jdwilliams1
So I do not need the ether since it is a fiberglass boat correct?
Also, I see you recommend the Rustoleum Primer, but what paint do you recommend? Do you add the hardener to the paint?
Woodonglass
Rustoleum all the way.
Primer and Paint. No hardener in the primer
