Re: paint to seal out water
You can buy matching gel coat in spray cans actually. Its a bit on the expensive side, particularly if its for a shade they don't have off the shelf, but you can buy it. Awl Grip, the color coat, is made for above the waterline use only. It will blister if used for prolonged soaking. From the waterline up its OK for years, but not below. Any exterior paint will be even worse than Awl Grip. Same thing goes for any of the other paints that are not specifically bottom paints. There is one exception, and its sort of obscure.<br /><br />Awl Grip makes a paint that is called "Barrier Coat". Its a 2-part paint, hard as nails, white in color. It is waterproof and in fact is made for waterproofing hulls. Normally it would act sort of as a primer for a further application of an anti-fouling bottom paint. However it can be used alone up to the waterline and then a bootstripe followed by either your existing gel coat or if its banged up and ready for repairs and painting then an Awl Grip (or whatever) top coat.<br /><br />Thom
