sportrider
- Joined
- Jun 4, 2014
- 129
what is a recommended paint for painting over glass? I'm carpeting over it but I was going to paint it first, do you think it's overkill to do this?
I have painted over many different surfaces with most of that being metals. I did paint my OB and it had a glass cowling and I used regular automotive catalyzed acetylic enamel paints from PPG. But I never painted as an expert and therefore will only explain what I did as an amateur painter that has had some very nice success. I started out with bare fiberglass and sanded that surface with 600 grit wet and dry. Then I sprayed PPG K36 primer, even a few coats. Then I block sanded that with 600 again until I was pleased with the looks. And this is a great place to say that any paint job finish is always done in the prep work. Don't think that top coat will cover up any imperfections in the primer work. Once I had the primer work finished to my liking, I sprayed a few coats of the actual top coat using again PPG automotive paints with hardener. After that dried/cured, I topped that off with a few coats of PPG clear coats. I think it came out looking very nice. And all the colors and art work designs are paint. Not any decals either. So that is my painting ability and sequence. There are so many others that have come out extremely nice and they will chime in as well... So many ways to accomplish the result YOU want...
