Painted Anodes?
fdmsiv
Does painting/coating an anode effect the efficiency or life of the anode assuming there is a good connect between the anode and base metal?
JB
Re: Painted Anodes?
The anode must also have a good connection to the surrounding water. Painting it seals that out.
5150abf
Re: Painted Anodes?
The purpose of an anode is to redirect corrosion, it is intended to corrode easily so by painting it you will make any corrosion find the next easiest spot to set up shop, which means the hull or engine so NO don't paint it.
As stated clean it of and make sure it has good contact with the hull or engine.
mphy98
Re: Painted Anodes?
no painty no washee :D i second the before opinion, paint will keep you from having a proper ground and diminish the sacraficial anode alltogether
Tim Frank
Re: Painted Anodes?
Painting the anode will greatly extend its service life......which is a bad thing.:)
You shouldn't do it.
