Re: Painted boat, now what
I would suggest using 1000 or 1200 grit after you're done with the 600-800 grit, and then use a liquid machine compound and a high speed polisher, rather than a rubbing compound. Just be careful not to burn the edges and you should be alright. before you do anything, however, you must make sure the paint is totally cured.
