Painting A Boat
ThomWV
The title says Painting a boat but maybe it should say, how we painted our boat. I don't know much about painting other than what we did with our 23'walkaround over last winter. Another thread on the subject prompted this one..<br /><br />Our boat is a 1991 23' walkaround cuddy. It has an 8' 6" beam and a full transom, with a bracketed outboard.Over the years it has taken its share of bumps. We've run aground a couple of times and bumped a dock a little harder than we should have more than once. I had one one crude repair on the transom back in 2001 that I painted over but you could see it, there were other noticable but not bad scratches too. Then we hit a pile.<br /><br />
<br /><br />I was already thinking about doing some repairs, now I had to. <br /><br />I began our project by cleaning the boat completely.We washed it several times using every harsh detergent we had. The boat had not been waxed since the previous spring (7 months earlier) but we still scrubed it ending up with an final wipe down with acetone and clean rags. After that I put some paper in the old DeWalt 6" random orbit sander. I would tell you I did this with 240 grit paper but to be absolutly honest with you I'm not sure.<br /><br />The sanding with the electric sander was really just a way to commit to the job to be honest about it. After I had scuffed (and that is the right word) the entire hull with the thing I had no choice but go forward. With the hull sanded I took to making the repair to the hole. I had already ground out all of the damaged glass and peeled back the interior material to expose the glass. I began on the inside and built up the repair. The finish on the outside was done in epoxy and finished with NAPA's microlite auto body filler, Plain glazing putty was used here and for scratches too but so little is left after sanding that the camera can not capture it. The microlite holds up on boats. The applicaton is probably less than a hundredths of an inch thich anyway, almost all of the patch is pure epoxy. Blending in the flair of the hull was a real treat, it is a compound curve and took some serious sanding to get right. I probably had 10 hours in that repair alone.<br /><br />At about the same time all this was going on I decided to install one of the new high performance in-hull transducers Airmar had come out with. So I removed my existing thru-hull and had to glass the hole shut. By boat was not high-end on the day it was made so I had some concern that there might be voids in the layup of the hull under where the transducer would go. I had no efidence for this, but I was concerned. So I broke out my grinder and removed most of the hull material, right down almost to the gelcoat skin, in an area just a bit larger than the transducer's tank (about 6"x12"). So I had that hole to glass up and then I went ahead and rebuilt the bottom up to an almost flat pad on which to mount the transducer. There were also a couple of other scrapes that I filled with a mixture of West System's 404 High Density Filler and epoxy and then sanded fare.<br /><br />So now we are to this point:<br />
<br /><br />With all the repairs done we began the sanding. We sanded with progressively finder and finder wet papers ending up with 360. This was straight forward work and my wife helped with quite a bit of it. She could do one side in a day but she would stop after a few hours. I don't know what's wrong with the old girl. I got to where I could do a between coat sanding of the whole hull with 240 grit paper in about 4 hours. Just to put this in perspective, both my wife and I are in our late 50's. So this isn't something that any reasonable healthy person shouldn't be able to tackle.<br /><br />I had decided to paint with Awl Grip earlier in the year when I was just toying with the though of cosmetic repairs. I spend a good bit of time in the company of some of North Carolina's custom boat builders and one of the who's advice I have great respect for said it was the only thing to use. Considering that the boats the man builds (and paints) cost over a million dollars per hull it was pretty much a no-brainer for me.<br /><br />Awl Grip's web site has a downloadable Application Guide that became my bible in the month or so while we did repairs. I followed every step and direction in their guide to the T. I used their products only, I did not try to substitute anything, nor would I had someone told me of some money saver. I used their system start to finish. If I had used InterLux's paint or 3M's I would have done exactly the same thing with their systems. I suggest you do the same.<br /><br />As good as the Awl Grip guide is it still lacks in one way. It really doesn't talk much about application. I will.<br /><br />We do not have a building I could put the boat in and because our place is very hilly I had no choice but park the boat right beside the road. This is where it would be painted. I do not have a compressor. I have only a bit of experience painting a couple of cars and motorcycles, but even that was years ago. It became clear to me almost immediately that spraying of any of the 2-part paints wasn't something I was going to be doing. To put it bluntly the stuff is too dangerous for my liking and I was not willing to toy with my health - which is currently good. Application by either brush or roller was said to give good results, that would have to be good enough. I would prepare as if the boat were to be sprayed in black and then I would roll it in white.<br /><br />I had some experience with rolling and tipping from the previous winter. I build a tackle box that would later be mounted in the boat. The box was made from plywood, glassed over, and then cut out for inserts that hold those plastic Plano Boxes. The box was then coated in homemade fairing compound and sanded. Then I painted the box using Interlux Bright Sides. This was the only time I had rolled and tipped anything. In fact I had not even heard of the process before doing the box. In short, for those who haven't seen it, it works like this. Paint is applied with the roller to the surface but it is generally applied quite thin. After the paint is evenly distributed make a final pass with the roller and then come back immediately with a dry paint brush.<br /><br />
<br /><br />What you will be doing with the brush is not painting in any sense. You will be just barely dragging the very tip of the brush across the paint with as little pressure as you can possibly apply. No paint will have been put on the brush and in fact if you do this right at the end of the painting session the brush will barely need to be cleaned. You are trying to touch the paint with the brush but get no paint on the brush. You will pull the brush down the paint in one direction only and you will make one deliberate stroke only, never going back over the same spot but moving over just a brush width and doing the next stroke. What you are doing is called knocking down the dipple. The dipple is that little bunch of raised little lumps in the paint where it pulled off the roller face. Most of these will normall lay down as the paint settles out but if you can remove the majority of them immediately then the natural process, which leads to the the finish's ability to reflect a true image, then the natural process is enhanced and the finish shows it.<br /><br /> Roll in an direction you like but only tip moving down if you are doing a hull. The reason for this is straight forward. If you move the brush side to side across some number of vertical passes of the roller what you end up with is hundreds of individual brush strokes as you go around the hull. On the other hand if you brush vertically what you have done in effect is covered the entire hull in one single brush stroke from top to bottom. I can not explain it any better than that so if it makes sense to you that's good and if it doesn't just trust me on it, brush vertically.<br /><br />Now I need to give a credit. As I said, I am not a painter and have little experience painting. It doesn't help anything that I do not care for painting either I suppose. In my search for information on applying Awl Grip I ran across a web site hosted by a fellow named Tim Lackey. Mr. Lackey refinishes sail boats and has a web site that is simply a wealth of information on how he goes about that.<br /><br />You can spend days at his site, which can be seen at http://www.triton381.com/ and what got my attention was his parts on painting. I sent him an E-Mail asking a few questions on the subject and he came back and told me more than I could have ever hoped for. I can not thank him enough for the time he took in walking me through the painting process. He is an awfully nice fellow.<br /><br />We began by rolling on a coat of Awl Grip's 545 primer. This is a flat white primer and using it was really as much practice for us as anything else. We tried tipping the primer right from the start, but it was clearly a waste of time to do that so we quit. Our painting technique was horrible and so our between coat sandings took some time. I knew Awl Grip is applied thin, but I had no idea what thin really meant. I was applying it too thick (causing runs) and I was not using enough reducer, which also caused runs. We sanded. As every coat was sanded and as we were learning how to apply the stuff we spent a lot more time and a lot more money on materials than we should have. The main problem, as I would learn later, was that we were not using enough reducer. Awl Grip recommended something like 25% as the maximum (just from memory, if you use the paint look it up) but rather than be the maximum they should have called that the minumum. At any rate I also decided that sanding with just 240 between coats would be sufficient. The paint would cover to that level of sanding and I had heard the arguments for 'tooth' for the paint to bond. I don't beleive it but I used 240 anyway.<br /><br />Just as a side note, for those who didn't know it the surface area of a sanded surface becomes greater as finer sandpaper is used. Don't be to concerned about concerns about the paint not 'soaking in' in gel coated boats. What the heck, same paint be it Awl Grip or Imron or any other of the 2-parts is used on automobiles and airplanes and to the best of my knowledge paint doesn't soak into steel or aluminum either. However if you were painting a car or plane you'd probably prep down to 400 grit or so. Why not on a boat? In my case going below 240 didn't enhance the look so I didn't do it.<br /><br />We kept applying primer coats and sanding without reguard for if we sanded through to the gel coat or not. The goal was simple, to have one primer coat come out after sanding out any imperfections (as well as generally sanding the entire surface of course) on which there was unbroken primer around the entire hull. Because some areas where repairs were being made got several coats of primer as repairs were made and other spots got double treatment now and then too I could not say how many coats were on the hull. Generally it would be safe to say that the entire hull has 4 coats on it before we had an unbroken coat. After that we applied one more coat of primer and sanded it. By the time I was using the pencil trick.<br /><br />Oh, and I should have mentioned this. After every between coat sanding, and at least a couple of hours before a coat of paint, the entire hull was washed, dried, and then wiped down with acetone to remove any skin oils.<br /><br />Awl grip gets harder the longer it stands. You want to sand it within about 24 hours of applying the paint or you will be there forever. After about 4 days it is almost impossible to sand. Because of temperature concerns (minumum of 55 degrees) I was painting in the afternoons. The following morning I would walk around the boat with a pencil in hand. Any problem area got a circle around it, a large circle, and then the circle was filled with smaller X's and just swirls and such with the pencil. These had to be sanded out of course, once you draw on the boat there is no choice.<br /><br />The priming process was interpupted by winter and so somewhere between primer coats 1 and 4 you can insert January, February, and a lot of March. In the spring I just washed it down and contined as if winter hadn't happened.<br /><br />We began the color coat following directions to the T and I was getting runs. Tim told me to reduce more because thinner paint doesn't run as badly as thick paint. Who would have known? He was dead right. Here is the only trick to applying Awl Grip, it is 2-part but so simple it boggles the mind. Use more reducer than they say and then apply the paint as thinly as you possibly can. If you can do that and keep the bugs out of it you'll be pleased with the results. To give you an idea of how thin the paint was being applied consider this. When I finally got it right we were mixing up just 24 oz of material to coat our 23'x8.5' boat. I mixed up the initial batch using the maximum recommended percentage of reducer and then every time we dipped the roller in we added one cap full to the roller tray. That worked perfectly for us.<br /><br />Now a word on application. My wife is a better painter than I am, and for reasons I will never understand she seems to enjoy it too. When we applied paint she went ahead and actually applied and spread the paint. Her job was to get it on the boat and to make sure that there was complete coverage - but also to apply it as thinnly as possible. She used a standard GlasKoter quarter inch nap covers at first. These are rated to be used with 2-part paints and will not fall apart. They are good but the seemed to hold a lot of lint (that had to be picked out of the paint). In the end I was using a cheap cover, also 1/4" from my locl Ace Hardware. It had a lot less lint and also held up to the paint. I think they cost about half as much too. Anyway my wife use one of the standard 9" rollers and applied the paint. Then I came along about 2 feet (maybe the width of 3 roller passes) behind her. I had a small 7" roller that used a roller cover that had a nap about like felt. I had loaded my roller with paint initially but ran it dry ahead of janet before comming back behind her with it. What I did with that roller was very similar to tipping. I went back over what my wife had applied. If there were any runs forming I fixed them by thinning out the paint in that area. If a bug had landed I removed it and fixed it. I got rid of the lint and I hit any spots that were missed. Also, the smaller very fine roller knocked down the roller dipple my wife was leaving. So we didn't tip the final coats but we did something similar.<br /><br />Awl Grip the color coat doesn't act anything like Awl Grip the primer. The primer is difficult to work with. It will run on you in a heartbeat. I can not say enough good about the color coat paint. Tim had warned me not to expect too much from the first coat, that the stuff really didn't shine until the second or sometimes even the third coat. What he didn't tell me was that the appearane of the paint continued to improve for days after application. We sanded between coats, just as we had done with the primer, and on the 3rd coat we had one final unbroken coat after sanding. That meant that the 4th coat was going to be it. We had a good day for painting and so we put it on.<br /><br />When we were done (it took the two of us about an hour and a half to apply a coat) the paint looked real good. Somehow we had avoided all but one or two bugs (small ones at that) and no blowing weed seeds. In about 4 hours the paint was spectacular. The next morning neighbors were stopping as they drove by. It is hard to explain that a white surface can be reflective enough to shave from.<br /><br />
<br /><br />All that is good about our paint job comes from two things. We took a lot of trouble to prep the boat, both initiall and between coats. The second reason is more important. Awl Grip is just an outstanding product. It was the paint, not the painter, that made this project come out as it did. The paint is extremely hard, probably as hard as the original gel coat. The paint is amazingly reflective but that comes with a price. It can not be repaired by blending in a patch. With Awl Grip you paint a panel, not a patch. You do not wax Awl Grip. There is no reason to and in fact it will likely loose luster if you wax it and will yellow too. The paint is good for at least 10 years in the south, more in the north. The paint is expensive, extremely expensive, but not over priced.<br /><br />I would sugges this for amounts. I bought a gallon of primer paint (and whatever amount of hardner and reducer is needed for a gallon) but I could have got away with half that amount if I had known what I was doing and had used more reducer. In the final color coat paint I used a half gallon to do the 4 coats and still have the other half that I intend to use to do the topsides this comming spring. I'm also going to use it along with InterLux's non-slip additive to do my No-skid decking. The only thing I'm thinking about doing is masking off all but my cabin top an then applying a coat of primer to it over top of the color coat. That would give me a dull surface on the cabin top, which would greatly cut down on glare for the driver but not be much noticable from outside of the boat.<br /><br />So there are my comments on or paint job. They come from a reluctant painter and in fact I make no claim to be a painter to this day. We got a good job because of the material and a willingness to follow directions. I know there are 'tricks' to good paint jobs that I don't know a thing about. I'd sure like to hear some of them before I tackle that top side. What was your painting experience like?<br /><br />Thom
18rabbit
Re: Painting A Boat
I image the reason the guy you talked to that uses Awl Grip exclusively is for two reasons; (1) it’s good stuff. But there is other good stuff available, arguable even better stuff, but not by much. And (2), all the finishes can be termed as ‘systems’. As you point out so well, you don’t just brush them on. There is technique involved. When you get good at applying a specific finish system, you want to stick with it. Artists that paint often use the same brand of paint for the same reason. They know how it ‘feels’ and can get the results they want.<br /><br />A local boatyard uses Awl Grip exclusively, too. I was talking to the manager and he mentioned Awl Grip is good stuff and they have so much experience with it they would be foolish to start another learning curve for a different system. They know, based on humidity, weather, etc how to mix and apply Awl Grip at any time to get great results. The yard also has a marina that sells more Interlux products than Awl Grip. The mgr said Interlux is good too, but they change their product line too often, he wants to stay with a quality system that he knows. Fwiw, Interlux and Awl Grip are sister companies owned by the same parent company. The folks at Interlux deny Awl Grip exists and visa-versa; they don’t talk. Typical dysfunctional family. :) <br /><br />You did a beautiful job on your boat … and on that tackle box! I don’t remember seeing pix of it when you first posted your Awl Grip photos.
Mark42
Re: Painting A Boat
Thom,<br /><br />I remember reading about your paint job last summer. I'm wondering how the paint held up where it was in contact with the water all season. Any problems there?<br /><br />Looking good.<br /><br />Mark
ThomWV
Re: Painting A Boat
I would say that in the last year it may have lost a little bit of its reflective ability, but that also might be comming from the fact I haven't washed it all year and I towed it 500 miles back home last month. Still, I think the shiney may have decreased a little bit. It still looks at least as good as a new hull though. Somehow we made it through the year without putting any scratches in it anywhere. I am also pleased to say that the stains that I used to get from the exit side of the scuppers can now be simply wiped away with a dry or damp rag. It used to take rubbing compound. I also noticed that gas stain from burps out of the vents just wipes right off, and I used to have fits with that in the summer. Anyway, so far so good.<br /><br />Actually the boat builder friend of mine is just one of several in the immediate area where he is located to use Awl Grip exclusively. As is the case with a number of the smaller custom builders he doesn't paint his own boats and the boats do not go to the painter. The painters come to his barn to paint his boats. So in this case its not what the painters are most accoustomed to that necessairly gets the nod. He wants Awl Grip and if they can't shoot it he gets another set of painters. I am pretty sure I know the reason, but its cultural, not economics or market that is driving the their insistance on the stuff.<br /><br />You'd think that Imron might be the paint of choice if not for price then at least because of the fantastic color availability. I have no doubt that it too is a great boat paint and I have heard that excellent results can be had from it by rolling and tipping too. Even if you couldn't do it yourself there must be a zillion body shops that shoot Imron so finding an experienced painter wouldn't be as hard either. Who knows?<br /><br />I do think that looking at it as a system is a key to success though. It doesn't matter who's paint you buy, use the materials that they say are compatable.<br /><br />Oh, the box. It was painted with InterLux BrightSides paint, not Awl Grip. I just put it up there because it was the first thing I ever tried rolling and tipping. It was a very good place to learn, a small flat surface that I could orient any way I wanted and was easy to reach as well. <br /><br />I think it was Tim, but it may have been someone else, that suggested to me to first paint a sheet of masonite or an old car hood to see how the paint worked. I actually did that but not so much to get practice but to get rid of lint. I picked up a half sheet of that thin masonite board at Lowe's. When we began painting the first thing I'd do was pour a little reducer on the roller and roll it around on that board a bit to dislodge lint. Then as soon as it was loaded with paint the first thing we hit with it was the masonite, once again, to get the lint off. It seemed like most of the lint came off of the rollers after just a swipe or two on the board, at any rate it left a lot less in the paint on the hull. Oh! A lesson learned. The first board I bought to do this with was a 4x4 section of that peg-board. That's the masonite with all of those *** **** holes in it. If you load a roller with paint and pass it over one of those boards it instantly deposits 3 pounds of fine sawdust that comes out of those holes on the roller cover - forever rendering it useless before it even got to the hull. Not so bad if it had been with a 99-Cent Ace Hardware special, not so good with a $5.99 GlasKoter.<br /><br />What other tips? Here's two. You can buy a box of 1,000 wooden tongue depressors (big popcicle sticks) for about $5. Nothing better to mix paint with. Buy a dozen of those plastic measuring can's before you start the job, most of them in that 1 qt size and the rest in the next size up. Make sure it has graduations on the side in Oz's. When you mix your paint add the hardner to the paint. Its easier to see where the level is through the plastic can that way. Don't guess on the mixing quantities, measure everything!<br /><br />t
Mark42
Re: Painting A Boat
Thanks Thom! Lots of good info there. I found that I had printed an earlier post of yours and put in my boating folder. This one is a keeper too!<br /><br />Mark.
ThomWV
Re: Painting A Boat
Whoops, I should have mentioned this too. If you look at the picture of the boat you will notice two creases in the glasswork that run fore and aft, one down at the waterline and the other up near the shear line. In each case the step up is about a half inch in a tight radius. So the rollers would not fit into the inside of the curve.<br /><br />I bought a couple of those Preval sprayers to deal with them. As we applied paint I first went ahead of Janet and sprayed just a line across those creases and above and below each of them a couple of inches. I sprayed very very lightly. Then Janet just rolled up to them but lifted the roller as she came to them. It gave a seamless transition into the stuff that I had just sprayed. We used he same paint and dumped the excess from the Preval back into the roller tray when we got back to the starting point.<br /><br />Oh, on the starting point. We started right on the bow. We painted about 6" to the starboard side of the bow and then came around and went down the port side, across the transom, and then back to the bow. The little 6" strip was tacky by the time we got back but the single roller pass where it blended in did indeed do just that, blend right in. So even though it is a roller job it is essentially seamless.<br /><br />Also, because I was installing a new engine at the same time I had taken the bracket off the trasom. I went ahead and removed the trim tabs too of course, and in doing so I ripped off a good sized chunk of glass. 5200 really is sticky stuff. So I had to repair that first. Actually I was glad to get the screws out from the trim tabs just to see for myself that they didn't have any water behind them. Same thing for the bolt holes for the Bracket. All the holes came up dry. The transom, 3-inches thick, showed no signs of deterioration other than some erosion below the Garbor drain.<br /><br />I don't know what cause some of the glass to be ereoded below the drain but I can tell you what I did about it.<br /><br />I removed the drain, which was just a matter of pulling 3 screws, and out it came. Mine went in thru some pretty sloppy glass work to the inside of the hull. At least no wood was exposed so I cut a short length of PVC tube (1" I think it was) and used 5200 to attach it to the inside of the Garbor drain. Vanity had me polish the old bronze Garbor to a mirror sheen, it really looked nice. Then ran a wire brush inside the hole to clean it out, swabbed it with a rag and lots of acetone too. I folleed that up with a paste I made up of epoxy and West System's 404 High Density Filler packed around the PVC tube as I pushed the Garbor back to its hole. I patched the eroded glass on the outside (which had been ground clean with 36 grit paper and washed with acetone) with the same paste. After it set up I removed the Garbor again Now it had a clean channel made from the glassed in place PVC tube and a gasket made of 5200 where it fit into the hull. I finished the outside and hit it with the Awl Grip primer and finish coat too. <br /><br />Actually I did a couple of little improvements like that while I was in the process of preparing for the paint. We had already removed the rub rail so that was replaced. I made a new bow pulpit out of Black Walnut because my old glass one was delaminating. I enlarged the drain for my anchor rode locker and some other small glass work.<br /><br />To me it just seems that the glass work and the painting go hand in hand, which is why I talke about the two together. My wife doesn't have anything to do with the glass work. In fact everytime I hit the pump on the old resin bottle I prepare myself mentally for 2 weeks of lecture on the environment and the sort of azzhole I am for what I'm selfishly doing to it. Chalk up one more point for Epoxy over Polyester, Epoxy's smell doesn't raise the alarm level in my household anywhere near the way Polyester does. That alone is worth the premium in price to a man of my temperment.<br /><br />I just thought of another way to describe what you are trying to do when tipping paint. You are trying to brush the rolled-on paint so lightly that you never leave a brush mark.<br /><br />Let's see, what else? I mixed the paint in those plastic cans, being very careful about measuring and also waiting the incubation time as directed (you mix the paint and then let it set for some period of time - maybe 15 minutes). We then only poured enough paint into the tray to wet the roller and maybe enough for two or 3 more loads. We kept the rest in the cup, covered, and in the shade. The days were cool anyway. As we added more paint to the tray we also added about a cap full of reducer. That was just to replace what evaporated. We would also add more if the paint seemed like it wanted to run.<br /><br />Let me explain that. It has always seemed to me that a thick paint would be less likely to run than a thin paint. The Awl Grip paint itself is qite thick, but the reducer brings it down considerably. Think of it as being the viscosity of cream when I say thick and the word thin means like water. So it never occured to me that if a paint was running the thing to do would be to thin it out. That seemed counter intuitive to me. Well, it isn't. Here's how it was explained to me that got me straight.<br /><br />The reason a thick paint runs is that you have to apply it in too heavy a coat because of its inability to spread well. The problem isn't that the paint is to stiff, its that its to thick. So when you reduce the paint it gives you the ability to spread it more thinly, which means that is no excess paint there to sag or run. More reducer means thinner paint which can then be spread further and so will have been applied in a less thick coat. Less thick coat means that there is no excess paint to sag or run. It works. And the thing is that as you thin the paint more the finish not only becomes better but you save more and more money because you're using less of it. Reducer costs about a forth as much as the paint.<br /><br />Of corse that is not to say that over reduction would be a way to save money. It would be a disaster to over reduce. I'm just saying that it is less expensive to do it right that it was to do it wrong. Also that what I had believed about paint turned out to be dead wrong until another way of looking at the problem of sags and runs was explained to me by someone who knew what he was talking about. That is what Tim did for me and I really appreciated it.<br /><br />I'll add more to this as I think of stuff or answer any questions, but I'm sure there are lots of guys who know more about this than I do. I only did it this once so I'm certainly no expert.<br /><br />Thom
Ironside
Re: Painting A Boat
A silly question for you Thom . How did you paint were your boat sits on the trailer?<br />does rolling it back and forward work or does that mess up the job? curious I have a 1974 21' Fiberform boat with a similar trailer
swimmin' for shore
Re: Painting A Boat
Thom, I'm curious about the same thing as Glutton here. I see that you didn't answer this then, but I'm wondering if you have the time, if you'd be so willing. Thanks a million.
