Painting a engine advise needed
acdc96
Just cleaned the engine in my 21' cuddy. Got all the gunk, grease, oil, etc. off the engine and engine compartment. I need to touch up some areas with some paint (mainly intake manifold). I don't want to use spray paint because of the over spray. It's a mercruiser engine from the late 80's. It's not a gloss paint it looks like satin. It needs to be able to withstand gas and oil being on it. I'm very good at prepping surfaces for paint. Any suggestions?
Ayuh,.... Rustoleum industrial enamel,....
I would use a rattle can and a cheap drop cloth to protect for overspray.
midcarolina
You will get the best results if you use rattle cans........take the time to mask and tape off adjacent areas, set a box fan up to pull over spray out and away.
acdc96
I will use the Rustoleum flat black engine paint. I've used it before and had good results. Now I gotta go buy a couple rolls of masking take. I Like the box fan idea. But it's gonna suck mounting it in that area. Thanks all for the input!
