painting a fiberglass boat
icy
I have a 17' 1973 Lund fiberglass boat (model unknown) that is "70's" green.. I would like to update the color as the boat itself is in excellent condition. My question is, how hard is it to do this? Do I need to know anything special? Can I use automotive paint or would it be better to find marine paint? Thease are some of the questions that come to mind right now, but im sure ill have more.
Corey
drewpster
Re: painting a fiberglass boat
Corey I started the process you about to embark on the end of last summer. First there is nothing difficult about painting a boat. However it is time consuming if you want the best finish you can get.
There are those who say that automotive finishes work well on boats. I have heard an equal number say they do not. I have a good friend in the automotive painting business. When I asked him about the subject he advised I use marine finishes. He and I agreed that no matter what opinion you come across, it is better to use industry specific products.
One advantage of marine paints over automotive is the way each is applied. Automotive paints require spray equipment to get the best result. Marine finishes are designed to be applied with a roller. Each paint manufacturer has their own system of applying the paint so it is best to follow their recommendations. I have experience with Interlux marine paints. (specifically Brightside and Perfection one part and two part polyurethanes) It is applied using a short nap roller then a china bristle brush to "tip" off the paint to flatten roller marks and bubbles. The paint dries smooth and has a high gloss similar to new gelcoat.
Their are several brand name marine finishes on the market to choose from. Interlux, Petits, Awlgrip, to name a few. They all have websites and complete prep and application instructions. I suggest you look them over.
You don't need to know anything special. Just keep in mind that the quality of your prep work, (sanding, priming, filling and fairing ect.) are what make the paint job. The best paint in the world won't cover bad preparation. Interlux's website has some good videos to show you the process. Trust me, you won't regret the result. My boat is 38 years old and painting has been the best move I have made so far.
Below are some pics of the boat when I painted the deck. They do not do it justice.
http://s136.photobucket.com/albums/q187/drewpster/?start=20
Chris1956
Corey, If you plan a two-color (deck and hull are different), you can use single part polyurethane on the declk and two-part polyuethane (below the waterline rated) for the hull. Prep all surfaces with sandpaper, eventually sanding to 200grit wet/dry paper. Prime according to maunfacturers instructions and spray or roll and tip.
Saskatoon2005
Corey,
Please take pictures of your work and upload on here. I love to see a restoration project on here....Good Luck!
Patrick
icy
it not so much restoration so much as customization.. i dont have a lot invested in it at this point but you get what you can afford right? I'm sure that I will be spending plenty of time on here in the future as there are a lot of things that I want to do to this ol girl.. i believe it has a lot of life left in it yet.. Just need to do some updating on her to make her do what i want her to do!!
