Re: Painting aluminum hull
i pressure washed, and used an orbital sander, then another good hose down, let it sit and dry. keep the paint moving, light coats, and come back another light coat. i worked in about 4 ft sections, in the sun, it dries quickly. i have also used the roll and tip technique, where you roll the paint on and use a brush to level it.
this is one in progress, roll and tip, yellow is finished, black is just prime coat, will get black gloss, for finish. this boat was so bad, had to 2 coat it
