is there any type of sealent paint for the bottem of an aluminum boat hull,that would help when and if rivets become loose again? any help is<br />welcome,thank you
Make sure the rivets are as tight as possible, then spread a product called "Gluv It" on the rivets/seams from the INSIDE.<br /><br />Gluv It is available here.<br /><br />www.westmarine.com
Might try to reset the ones that are in there, Just get someone to back the rivit and whack them with a hammer, then put the sealent on the seams on the inside, I would look at how you boat sits on the trailer sound like that might be where the damage came from, unless you hit somthing. Hope this helps.
