Painting Boat and Trailer
Proselect
I am going to get started this spring with repainting my aluminum boat and sandblasting the trailer and repainting. My question is: Does anybody have any tips or ideas for setting the boat down without the trailer so I can repaint it and recarpet the floor. I need to find a way to brace it in a way that it won't get in the way of prepping and painting. I plan to sandblast the trailer and repaint it as well. Any tricks or tips for recarpeting and painting please share. I want this project to go as quick and smooth as possible.
Home Cookin'
Re: Painting Boat and Trailer
Need to know the size of the boat and do you have a roller trailer? We used to take our 16' Starcrafts off the trailer in the yard every year to paint the bottom. Raise the tongue, let it roll off so the stern is on the grass, lift the bow and pull the trailer out. Reverse the process with the winch to put it back on. Takes a few people. Be mindful of the lower unit.
If you have bunks only, maybe slide some dowels for rollers between the hull and bunk and roll off?
There are elaborate plans for jacknig the boat up and building braces under it and pullnig the trailer out. Having a boat propped up while you are working around (or under) it is scary.
One of the simplest ways to lift part of the boat off the trailer is to use the tongue jack and blocks. For example, lower the bow (raises the stern) block the stern, raise the bow and the stern part of the trailer lowers under the blocked stern. But be careful and chock your wheels!
Lift your boat off with a sling or lines on the stern cleats and bow eye but don't leave it dangling as the weight can warp a hull after time. This is not a good idea for heavy boats, obviously.
Proselect
It is a 16 foot aluminum fishing boat with an outboard. The trailer is a shorlander roller trailer. Seems pretty easy to roll it off onto the grass or something, but we need it in the shop propped up somehow so we can work on it and paint it. I was thinking of building some braces out of wood to cradle it. Not sure if that is a huge project or not. We need to build them small enough as not to interfere with the area that is going to be painted.
Home Cookin'
roll it off in the shop with an old tire (no rim) at the stern to land on.
stylesabu
MY 16' tinny is in my garage on 2 jack stands and a 4x4 and a couple of cinder blocks. I rolled it off the trailer by myself and a 2 ton floor jack. I have posted before on this.if you gut the boat completely, then rolling it over would be a good way to paint hull
