Painting Fiberglass with Durabak
nightvision
Hi all, <br />I'm will be painting the inside of a fiberglass fishing boat with Durabak and need some assistance with square footage.<br /><br />The boat is 13 feet long and the width is 5 feet at the widest point.<br /><br />A gallon of Durabak can cover 60 square feet.<br />I sure someone has paint a boat of this size before. <br /><br />Thanks.
bluewater19
Re: Painting Fiberglass with Durabak
Nightvision,<br />A gallon will be plenty. I did the inside of my 19'boat with a gallon last spring. Make sure you read the directions and prep it then wash down with xylene. <br />I had a pint or so left when I was done with mine. I put the first coat on regular and the second pretty thick. I think you can't go wrong with this stuff!
jimr
I am doing the inside of my boat with skid no more from evercoat a gallon should be enough to do 2 coats.
BillP
Length x Width = sq ft (13' x 5' = 65 sq ft). Measure each section you are painting for exact total.
luisjg
i love that durabak stuff ,,irealy works great.<br /><br />its sticks like crazy though,,use gloves .<br /><br />and also thin it with xylene and it will cover more, and make sure you mix it very well with a drill mixing atachment.
