62cruiserinc
- Joined
- Oct 30, 2009
- 295
I am in the process of painting my Merc Alpha 1 outdrive.
I have searched and read the previous posts on outdrive painting.
The outdrive is in my shop and off the boat.
A couple of questions:
1) I have a can of spray zinc chromate primer. I assume you only have to spray the bare aluminum parts of the outdrive (once you have sanded everything, done the wash, etc) with zinc chromate? Otherwise I will probably need more primer.
2) The posts seem to fall into two camps for the final black paint: using a rattle can (rustoleum, etc) or using a catalyzed enamel. I am planning on using a gloss black enamel tractor paint with the hardener, even though it means I will have to brush it on. Anyone care to comment on this?
Thanks for the help
Steve
Thanks for the help
Steve
