Panther outboard bracket
KJM
Did anyone else find the spring tension in these is way too much? Even with a 9.9 4 stroke on the bracket i couldn't lower the motor against the springs. I eventually had to remove the lower spring and only then could i get it to move!
dingbat
Which one do you have?
Seeing units rated anywhere from 12HP, #115 to 35HP, #263
