Parked the boat 10 months ago..............
JRJ
1/4 tank of fuel and no additives. Think it will start?
Frank Acampora
Re: Parked the boat 10 months ago..............
I never put stabilizer in my gas to over winter and have not had any problems. Give it a try. It will either start or it won't. If it doesn't, try fresh gas.
MikDee
Banned
Sometimes I do, sometimes I don't, I'm not consistent,,, lol,,, never had a problem starting after the winter, at least not because of gas. I'm with Frank on this.
tashasdaddy
if it doesn't start or acts up look at the carbs. (varnished up)
JRJ
Well, I turned on the key and let the fuel pump do its thing. Then she fired right up. EFI 4-S and Chevron gasoline.
What a relief.
tashasdaddy
well you didn't tell us the whole story about what you had. fuel injected 4 stroke. makes a big difference. than a carbed 2 stroke. still advisable to stablize the gas.
gss036
Chevron puts Techron in thier gas which makes a huge difference. I have a friend who bites the bullet and run it all the time. I don't myself because it is normally abot 25-30 a gal higher in price and 2 MPG, that addd up to a lot of $$$.
I add Techron to my vehicles to help keep the injectors and O2 sensors clean and keep the check engine light off.
JRJ
Right on with Techron.
ricksrster
So, Would you fellas recommend using a bottle of Techron Concentrate in an outboard?
