Going thru old inventory and came up with a remote control with no part number.Maybe someone can help.
It's definetly OMC and is definetly OLD,as well.
It is white with a chrome handle.The lower part of the handle has a "window" and you can select Forward (fast and slow),Neutral,Start,and Reverse (fast and slow).It has two steel,vinyl-coated cables,about 1/8 diameter.The instruction book indicates the cables go to a "slave" cylinder that does the actual throttle and shift.
I want a part number because being a Johnson dealer, other dealers can access my inventory when looking for parts.Probably the only way to get these parts off the shelf.
DHP
DHP
