skoboten2day
- Joined
- Aug 28, 2018
- 27
2 questions. I replaced the diaphragms/washers in a VRO fuel pump versus swapping it out for a non-VRO fuel pump. I don't think the issue was worn parts because the old ones looked good. The problem seems to be the old fuel hose and especially a leak at the male fuel tank connector. I plan to replace the hose and connectors with OEM.
1st question. See pictures. Which part do I need since the VRO is disabled and I don't need an oil line/connector? Can you please give me a part number or link where I can buy?
2nd question. See pictures. When putting the fuel pump back in the motor, a 5/16" bit slipped down into the cavity of the motor. Can't find it anywhere and I think it went down a hole where the lower cowlings meet. I don't know if I can retrieve it since it's at such an extreme angle and I'd have to take multiple parts off to get a grabber or magnet in the hole. Any idea what's down in this hole and if it's a show stopper if I can't retrieve the bit?
Thanks
Thanks
