Parts for Goodyear 1947 1G1 3 HP motor
BunnD
Any suggestions on finding a piston connecting rod and head for SeaBee 1G1 motor?
jimmacl
Re: Parts for Goodyear 1947 1G1 3 HP motor
Find an old outboard swap (check the AOMCI web site). There is usually a few at a swap ($50 bucks). Watch out Gale switched the drive shaft to a smaller one after 1947. Any 1945 to 47 3hp Seaking/Viking/Seabee/Gale should fit. Yours should be a 7/16 drive shaft.
Usually the bottom ends are messed up on those outboards. The drive shaft chews up the bushing leaving too much back lash. I got a motor with a thrown connecting rod looks like it was run with too lean of a mix.
good luck
jim
F_R
Piston is part number 590186, listed as unavailable---try www.sea-way.com
Con rod is 590007. www.marineengine.com has two in stock. $75 each. You really didn't want one after all, did you?
There is no head. Do you mean the cylinder?
BunnD
Yes the cylinder. Thanks for the parts numbers. Very helpful.
tmcalavy
Also try the free classifieds on the aomci site
