Parts for my Starcraft
straightleg
Looking for parts for a 4.3L gets confusing to me. So many different engines
Any manuals or service bullitins would be appreciated. I prefer Mercruiser/quicksilver replacement parts
Engine number C393247
Drive unit OC500002
Transom Assembly 0C489657
Want to get bellows, lower shift cable, trim pucks, and any other parts when dismantled.
Thanks
Gerry
straightleg
Re: Parts for my Starcraft
Don
When I type my serial number in it says I have a 1988 motor.
The serial number also does not match to what I have found on stamps on engine
Don S
Yes, it's an 88 motor, not uncommon for boats to have an engine/drive package a year older or even newer than the boat itself.
Boat year is Jan 1 to Dec 31, engines model years change in the middle of the year. Boat manufacturers also order engine packages well in advance of the boats being built, and they just keep rotating their stock.
The serial number you posted for your drive, 0C500002 is also incorrect, it should be 0C500020
The engine and drive numbers were originally installed in a boat with the last numbers of the HIN as 2C889
You posted the engine/drive/transom shield numbers and they match to your boat, so what are these other numbers you speak of????
straightleg
Don
Maybe i need my glasses checked. Will look again at serial numbers when I get my boat back next week.
Thanks so much for all the help you have giving me.
Am buying my next purchases from this website.
Gerry
Don S
The 02 is the same drive and ratio, it's just your boat shipped with the 20 number. Unless it was registered with the wrong number, which is also possible.
