Parts motor: 1972/1989
Hi,
I have the opportunity to purchase a 1989 Evinrude 40hp motor (sorry I don't know the serial/model).
I own a 1972 Johnson 40hp that runs well, but it's a pull start. Does anyone know if the electrical components on the '89 would work with the '72? I was hoping to scavenge the starter, solenoid, cables etc.
Furthermore, would any other parts be compatible? The seller is asking $200, and the least I've found the parts to convert my tiller from pull to electric is about $500.
Thanks for any ideas or input.
Daviet
Re: Parts motor: 1972/1989
Check the parts breakdowns for both engines and see what parts will interchange. I would think that with that many years difference that not a lot of parts will swap, but you should check it out. It would not be the first time I was wrong.
Al-53
the starter bracket will not fit.....the mounting is different on the bosses....
Al
Thanks for the response. I was affraid of that. I guess my shoulder will have to do for now. :)
Al-53
look for the bracket on Ebay....see them alot there.....early 70's
Al
