for arson damged engine:<br /><br />-a cowling<br />-electric fuel primer solenoid<br />-VRO replacement fuel pump (I am dumping the vro oil injection)<br />-splash guard (plastic cowling shroud underneath engine)<br />-tilt switch (the one mounted on the starboard outside of the engine)<br />-all hoses for the carburetor, VRO fuel pump, electric fuel primer solenoid<br />-for the bottom carburetor I need minlon float bowl<br />-water indicator hose fitting (the plastic piece exiting the engine) and hose<br />-main positive and negative cables<br />-control box with ignition/trim/wireharness/key<br /><br />if you can help--------------> seanpaddy@hotmail.com<br /><br />yours truly<br />sean
