Hi guys,<br /><br /> We have an old evinrude 5.5hp 1961 and i would need to have a display of the upper unit the headpower parts and if possible numbers .So, if you are able to help me I would appreciated your help. Thank you , I need you !!!
Hey Lyse as I'm reading your question en then the explanation of it I get mix up, so waht I can give you a clue is with the water pump kit impeller and plate, sierra has it impeller #183001 oem 434424 and pump plate is 183102 oem 305303 they do not have a whole kit with cup and gasket but with this numbers you can may be do something as far as the displays you want of the lower unit and powerhead I am in Venezuela so is not easy for me but I do have it
Thank you guys for your help. I bought the correct waterpump kit and I am very happy about that. When I need your help I know that I may count on you. Thanks again.
