bad coffee
- Joined
- Jun 21, 2013
- 24
Hey all,
I'm thinking about all the hairline cracks, dings, and scrapes that I need to fill on my boat. There's a lot of spots that need work. After I sand down the hull, and dremel out the cracks, can I use PB to fill the cracks?
When I mix up a big batch of PB for the new transom, there will be some left over. Can I use it to fill some of the spots in the hull. As long as the PB hasn't set, of course.
Will the PB work?
Will there be a bunch of hairy edges that need to be sanded down from the fibers?
Should I mix up a fresh batch for the bottom, instead of chancing the PB to set?
Would it be cheaper in the long run to buy repair compound?
Thanks in advance,
B
Will the PB work?
Thanks in advance,
B
