Pb mix for transom
Blown496
I got my cam on my new transom. First time mixing I figured about 7 sq ft to do taking quart of resin. The catalyst amount was cut in half per instructions since its 92 degrees. That was almost perfect and I had plenty of time to work it up. Can I do the same with pb?
Baylinerchuck
Yes. The hotter it is the less catalyst is needed. You add MEKP at 2% in 90 degree heat, you won’t have much time before it kicks hard.
Blown496
thanks I’ll try it with the half ratio for pb and tabbing.
