Re: Peanut Butter Resin Formula ?
Different people, different opinions. You can use PL to bed your stringers, but it's no better (or worse) than using air or foam.
If you want to use a peanut butter mix to bond them, I'd recommend just using wood flour (really finely ground dry wood particles, not sawdust) or a mix of cabosol and milled fibers. You mix the resin first, then mix in the dry ingredients until the mix becomes the thickness you want... typically something around creamy peanut butter. A mechanical mixer helps.
Erik
