yonipainting
- Joined
- May 18, 2008
- 86
So, all of a sudden I lost my trailer lights one day (lost power to them) Brake lights work, turning signals work. Same symptoms behind both of my tracks.
I tried to chase the problem today. Didn't find anything but ended up completely re-wiring the trailer. Symptoms stayed the same.
This is what I noticed : With trailer disconnected,from the vehicle, there is power on the light connector (vehicle side). As soon as I plug the trailer in I loose that power (ON THE VEHICLE SIDE ??? - no fuses blown). I disconnect the trailer plug, turn the lights off and on again - same story.
I then disconnected the ground on the trailer side. With ground disconnected, i plugged the trailer in - power stayed. As soon as I touch the ground wire to the trailer - power goes off !!!
That was the point that i figured this problem was above my pay grade
Maybe I should mention that I have LED lights on the trailer and don't know much about them. Everything was running fine since the beginning of this season.
